Column width
‎06-07-2011 08:03 AM
Not sure if this is the right place to raise this question...
How do you adjust the width of a column when looking at all tickets, I can modify the column by using 'Personalize List Columns' and add/remove etc
Would like to be able to drag the width of the column, like in excel etc
Is this possible or is it a limitation of the Toolset ?
- 25,666 Views
‎07-09-2019 10:36 AM
Thank you!!
‎10-17-2018 09:05 AM
Has anyone figured out a way to change column widths on a report that includes sc_req_item variables in the columns? The solution of applying Field Styles would seem to be a workaround for table columns, but not variables.
Johnny
‎10-28-2019 05:31 AM
Any update regarding this thread?
‎11-03-2019 07:00 AM
Nothing given the current list layout technology. The current lists in the "classic/platform" UI are built using a templating technology known as Jelly. Jelly does not support this. In the future, we may be able to do this as the underlying technologies change.
‎11-03-2019 10:15 AM
What about column width on reports?
Are there technology obstacles for this enhancement request:
