Connection error between ServiceNow and Sailpoint IdentityIQ
Steve41
We installed the following SailPoint IdentityIQ for Service Catalog v2 app and have been working with the SailPoint IIQ developer. When we browse to the Service Catalog and select our "Manage Access", we get the following error message:
Cannot connect to SailPoint IdentityIQ server. Please contact Administrator. Error Code 001- Check Admin Setup.
I have verified that our setup parameters are correct and the account we are using has admin privileges to IIQ. Any ideas would be helpful.
Steve
Milind Gharte
Hi ,
Here is a link which will help you.
https://community.sailpoint.com/t5/User-Help/I-m-having-some-problems-launching-apps-or-using-the-Sa...
If it helps,Please mark ✅ Correct and 👍 Helpful.
Warm Regards,
Milind
Steve41
Unfortunately this did not help.
GoSeeTheWizard
  1. Log into IIQ
  2. Go to your Applications -> Applications Definitions
  3. Click on the ServiceNow application name.
  4. Click the 'Configuration' tab and verify the ServiceNow credentials - URL, Username, Password
  5. Click 'Test Connection' which should show as 'Successful'
This should correct your connection to ServiceNow issue.
-GoSeeTheWizard
Shruti
Hi Steve,
Were you able to fix this error? If yes, could you please help with the solution
