Container split in not working in service portal?
sam332
     Container split is not working in service portal.created varibel set with container start ,end  and split,it is working fine from catalog side.But when i open same catalog from service portal side,it is not working(not getting splitted).
Sam
14 REPLIES 14
Ed13
It is strange indeed but it worked like a charm.
I have to add that in my scenario the split happens inside of a variable set.
it resolved my issue
I have working in a issue for months and finally found the solution! Really is strange how its works.
Thanks for your post!
Just as @Ney Bernardo have said, it's really strange that it works, but as long it dos work, i'm fine.
Thanks!
Djibyt
it's works thanks you
