Control variable visibility based on the selected Location's type (reference to cmn_location)
Dale Bersane
I am building a catalog item and I need to control the visibility of the form variable "A" based on the selection of variable "B".  NOTE: variable "B" is a reference to the cmn_location table. The tricky part is that I need to dot walk to a custom column on the location table to get the appropriate condition.
Goal: Show variable "A" only if variable "B" has a type of "C".
Example:  Show the "Desk Number" variable on the catalog form if the "Location" selected (on the form) has a type designated as "Desk"(custom reference column on the location table that is referencing another table).
Any help would be greatly appreciated.  Thank you in advance.
2 ACCEPTED SOLUTIONS
SAI VENKATESH
Hi @Dale Bersane
You can try the below script:
    var requestedFor = g_form.getValue('prefered_location');
	alert(requestedFor);
    var ga = new GlideAjax('GetManagerDetailsScript');//script include name
    ga.addParam('sysparm_name', 'getlocation'); // function name used in script include
    ga.addParam('sysparm_requested', requestedFor);
    ga.getXMLAnswer(callback);
	function callback(response){
		var answer=response;
		alert(answer);
script include:
var GetManagerDetailsScript = Class.create();
GetManagerDetailsScript.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getlocation: function(){
        var requestedFor = this.getParameter('sysparm_requested');
        var grcountry = new GlideRecord('cmn_location');
        grcountry.addQuery('sys_id', requestedFor);
        grcountry.query();
        if (grcountry.next()) {
            return  grcountry.country;
Thanks and Regards
Sai Venkatesh
Hi @Dale Bersane
		if(answer=="USA"){
                     g_form.setVisble('prefered_location',true);
@SAI VENKATESH where in the client script is the variable visibility being set?  Could you please advise.  TY
Hi @Dale Bersane
		if(answer=="USA"){
