Copy Work Notes from Problem to Incident and Vice Versa
Chintha Murali
Mega Expert
I have a requirement to copy worknotes from problem to incident and vice versa.
Please help me with this.
Thank you.
Hi @Chintha Murali krishna
Please find the updated Business Rules below (these will surely work 😉)
Remark: Make sure both the Business Rules are on Insert and Update + When = Before
Incident:
    var identifier = '[Comment Sync]';
    if (current.work_notes.indexOf(identifier) < 0) {
        var getProblems = current.problem_id.getRefRecord();
        getProblems.work_notes = identifier + '\n' + current.work_notes;
        getProblems.update();
})(current, previous);
Problem:
        var getIncidents = new GlideRecord('incident');
		getIncidents.addQuery('problem_id', current.getValue('sys_id'));
		getIncidents.query();
		while(getIncidents.next()) {
			getIncidents.work_notes = identifier + '\n' + current.work_notes;
			getIncidents.update();
Please mark my answer as correct if this solves your issues!
If it helped you in any way then please mark helpful!
Thanks and regards,
Kartik
kartiksethi
This requirement will have recursive work notes/comment updates so we need to have a workaround for this.
  1. Create a Business Rule on both Incident and Problem tables
  2. Business Rule names can be
    • Incident:
      • Copy Work notes to Problem
    • Problem:
      • Copy Work notes to Incident
  3. Both the Business Rules (BRs) should run on Insert and Update, and Can run on After
  4. Condition on BRs should be Worknotes changes
  5. Decide a common identifier to avoid recursive copy of comments on Incident and Problem
  6. Scripts are provided below:
Incident:
    if (current.worknotes.indexOf(identifier) < 0) {
        getProblems.worknotes = identifier + '\n' + current.worknotes;
Problem:
			getIncidents.worknotes = identifier + '\n' + current.worknotes;
Thanks and regards,
Kartik
Hi Karthik,
Thank you for the detailed explanation. I have tried your solution but it still doesn't work. Please have a look at the screenshots attached.
Thank you
Incident:
Problem:
Thanks and regards,
Kartik
Thank you. It works perfectly.
