CopyChange does not copy related list
samadam
I am using copy change functionality and listed an m2m table in the list in 'com.snc.change_request.copy.related_lists'. I checked the acl and itil has access to create records still the related items from parent change are not getting copied. Is there anything else that I need to check? I cannot create even as admin.
JerryJ071847183
Tera Sage
Have you kept the below things in mind while copying ?
1. Note: You cannot copy change details from a standard change.
2. New change tasks can be created when a change is copied. If your change record has associated workflows that create change tasks, then these change tasks may not be copied because the workflow creates them. Only manually created tasks are copied, if the workflow when creating the task sets the created_from field on the change_task table to workflow. The created_from field has a default value of manual.
3. You can copy details of an active or canceled change request to a new change request.
If not I would request you to check below link for more details
LINK
Also verify  properties that should be checked for copying change like  below
com.snc.change_request.enable_copy
For more details check below
LINK
I hope this helps
The property is enabled and custom table has access to create to itil users. Another custom table worked. Not sure what else to check, Are there any restrictions on not allowing copy on m2m tables? This is a m2m table
See this in the logs:
copyChangeRelatedLists: Could not copy related table u_Temp_table
@samadam
seems some issue when script ran
check this script include "ChangeUtilsSNC"
Runjay Patel
Hi @samadam ,
Just double check the change property. your related list should not be empty. If value there and still it is not working then you may raise HI ticket to get it resolve, as OOB functionality should work as expected.
