Create a business rule to establish a relationship between Application Service and Business Service
Nilanjan1
Dear Experts,
I am trying to establish a relationship between app service and bus service based on the data present in a field (App Service)  of the application service. I have created the script and created the type which will be needed for establishing the relationship. lot of restrictions are present in the client ServiceNow, which prevents me from adding a test application service and test business service to run the relationship mapping. Hence checking how this script can be best optimized. Also one more condition I have to put is to make the Operational status as non- operations in the application and business table so to say. Can someone guide ?
        var gr = new GlideRecord('cmdb_rel_ci');
        gr.addQuery('parent', current.getValue('application_service.sys_id'));
        gr.addQuery('child', current.getValue('business_application.sys_id'));
        gr.addQuery('type', '7959e7c41b684a90354d96859b4bcbff');
        //gs.info(' NB ' + gr.getRowCount());
        if (gr.next()) {
			//gs.info(' NBIf ');
            gr.setValue('parent', current.getValue('application_service.sys_id'));
            gr.setValue('child', current.getValue('business_application.sys_id'));
            gr.setValue('type', '7959e7c41b684a90354d96859b4bcbff');
            gr.update();
			gs.info(' NBelse ');
            gr.initialize();
            gr.insert();
})(current, previous);
Deepak Shaerma
Hi @Nilanjan1
Step 1: Define Relationship Type and Fields
Define the relationship type (if not already defined). Make sure you have the sys_id of the relationship type and know the field names you are mapping (for both the app and business service).
Step 2: Script Logic
Your script should include logic to retrieve relevant records from the application service and business service based on your criteria, and incorporate the operational status check into this query.
Step 3: Create or Update Relationship Records
For each matching pair, create or update cmdb_rel_ci records that represent the relationship between the application service and business service.
var AppToBusServiceRelationship = Class.create();
AppToBusServiceRelationship.prototype = {
    initialize: function() {
        this.relationshipTypeSysId = ‘YOUR_RELATIONSHIP_TYPE_SYS_ID’; // Replace with your type’s sys_id
    establishRelationship: function () {
        // Query the Application Service table for records based on some field that holds the relevant data
        var appServiceGR = new GlideRecord(‘cmdb_ci_service_discovered’); // Replace with actual table name if different
        appServiceGR.addQuery(‘operational_status’, ‘!=’, ‘non-operational’); // Adjust field and value accordingly
        appServiceGR.query();
        while (appServiceGR.next()) {
            // Extract the data which will be used to find the matching Business Service
            var matchingFieldData = appServiceGR.getValue(‘your_matching_field’); // Adjust ‘your_matching_field’ accordingly
            // Query the Business Service table for records that match the criteria based on app service data
            var busServiceGR = new GlideRecord(‘cmdb_ci_service’); // Replace with actual table name if different
            busServiceGR.addQuery(‘your_corresponding_field’, matchingFieldData); // Replace ‘your_corresponding_field’
            busServiceGR.addQuery(‘operational_status’, ‘!=’, ‘non-operational’);
            busServiceGR.query();
            if (busServiceGR.next()) {
                // If a Business Service is found, create/update the relationship record
                this.createOrUpdateRelationship(appServiceGR.getUniqueValue(), busServiceGR.getUniqueValue());
    createOrUpdateRelationship: function (appServiceSysId, busServiceSysId) {
        // Check if the relationship already exists
        var relGR = new GlideRecord(‘cmdb_rel_ci’);
        relGR.addQuery(‘parent’, appServiceSysId);
        relGR.addQuery(‘child’, busServiceSysId);
        relGR.addQuery(‘type’, this.relationshipTypeSysId);
        relGR.query();
        if (!relGR.next()) {
            // If it doesn’t exist, create a new relationship record
            relGR.initialize();
            relGR.setValue(‘parent’, appServiceSysId);
            relGR.setValue(‘child’, busServiceSysId);
            relGR.setValue(‘type’, this.relationshipTypeSysId);
            relGR.insert();
        // Else, the relationship already exists and we don’t need to do anything, or you can update it if needed
    type: ‘AppToBusServiceRelationship’
Please Mark this as Helpful/ Solved if this solves your query
Thanks & Regards
Deepak Sharma
Hello Deepak,
Thank you so much for the reply. however when I am trying to get the relationship established by using these two fields as a reference to each other, the script is failing. These fields are  'u_application_release_cit_id' in which value should match  to the business application correlation field. When I ran the background script all the gs.log are getting validated but giving me an error at the end. Can you guide through this ?
Error after running the background script
When to Run Tab is updated with the following
        this.relationshipTypeSysId = '7959e7c41b684a90354d96859b4bcbff';
        var appServiceGR = new GlideRecord('cmdb_ci_service_auto');
        appServiceGR.addQuery('operational_status', '!=', '2');
            var matchingFieldData = appServiceGR.getValue('u_application_release_cit_id');
            var busServiceGR = new GlideRecord('cmdb_ci_business_app');
            busServiceGR.addQuery('correlation_id', matchingFieldData);
            busServiceGR.addQuery('operational_status', '!=', '2');
        var relGR = new GlideRecord('cmdb_rel_ci');
        relGR.addQuery('parent', appServiceSysId);
        relGR.addQuery('child', busServiceSysId);
        relGR.addQuery('type', this.relationshipTypeSysId);
        relGR.query();
            // If it doesn't exist, create a new relationship record
            relGR.initialize();
            relGR.setValue('parent', appServiceSysId);
            relGR.setValue('child', busServiceSysId);
            relGR.setValue('type', this.relationshipTypeSysId);
            relGR.insert();
    type: 'AppToBusServiceRelationship'
Nilanjan1
Thank you so much everyone for your help and support. I was able to get it resolved through the following code and now I am getting the dependency as expected.
    gs.info("NB BR 1");
    if (current.application_service.operational_status == 2 || current.business_application.operational_status == 2) {
        gs.info("NB BR 2 NON OP");
        return; //skip relationship creation if either ci is non-operational
	gs.info("NB BR 3 : "+ current.u_application_release_cit_id);
    var businessAppSysID;
    var getBusinessApplication = new GlideRecord("cmdb_ci_business_app");
    getBusinessApplication.addEncodedQuery("correlation_id=" + current.u_application_release_cit_id);
	getBusinessApplication.query();
	gs.info("NB BR 3.1 count "+getBusinessApplication.getRowCount());
    if (getBusinessApplication.next()) {
        businessAppSysID = getBusinessApplication.sys_id;
		gs.info("NB BR 4 businessAppSysID "+businessAppSysID);
        gr.initialize();
        gr.parent = current.sys_id;
        gr.child = businessAppSysID;
        gr.type = '7959e7c41b684a90354d96859b4bcbff';
        var ins = gr.insert();
		gs.info("NB BR 5 ins : "+ins);
