Default filter on reference field
Udit Maheshwar2
Is there any way to apply default filter on reference field so that user can click on search and new window pop-up with filter applied by default at first and if user does not satisfy with the records obtained then he can click on 'All'' to get whole list. ??
Thanks.
The ability to set up a filter that is editable on a reference field is not currently available. I suggest you add it to the Idea Portal on the community. Our product managers review the idea portal for customer requests all the time. Sorry I didn't have an easy to configure (and maintain) option for you out of the box.
12 REPLIES 12
Aviram
Did anyone find a solution that will work in Workspace?
Bump
ralvarez
Here there is a solution.
