Dictionary Override related list is not visible
pawan k singh
Dear All,
I want to override 'calculate_duration' field in Requested Item table, which inherits this field from task table.
I am not able to see "Dictionary Override" related list in work instance. However, it is visible in my personal instance.
I checked "List Layout" of Dictionary Entry and also the Related lists of it but it is not there.
Need your input in this. Below Screenshot.
Thanks for your help in advance!
Pawan K Singh
12 REPLIES 12
I had checked [Madrid & Orlando both] and I was also able to see that in my instance as well. As this is not appearing in slush-bucket so it could be due to any before query business rule. Can you check?
Otherwise, I would suggest submitting a HI-Ticket to get technical assistance on this.
Monika2
Giga Guru
Are you talking about 'calendar_duration' field?
pawan k singh
Hi Sharjeel,
As described it is not there in Related Lists, check this image.
Pawan K Singh
Hi Pawan,
In case you have verified all the possible places and since this is for your client instance please raise a HI ticket with ServiceNow
Thanks Ankur, will take a look.
