Editable catalog reference variable
03-02-2026 02:39 PM
I have a reference field on a form. When I click on the “I” (Info) icon, it opens the record in a popup window.
Its portal side where I click on i button it is showing editable fields
I want to make that popup read-only, so users can view the details but cannot edit anything from the popup.
Important:
This is not a variable. It is the standard reference field “Info” preview popup.
Has anyone implemented this before? What is the best approach to make the Info popup non-editable?
Thanks in advance!
03-04-2026 01:19 AM
this link has solution
Make record preview readonly in Service Portal (all records)
03-04-2026 04:16 AM
Did you try the link I shared?
It has working solution
ref_decoration_disabled won't work for variables in portal
03-04-2026 07:23 PM
Hope you are doing good.
03-04-2026 04:03 AM
Hello @DevYadav ,
Please refer thread mentioned by @Ankur Bawiskar , follow all steps mentioned in that thread. It will work . I tried that it is working.
