Fix Script Help needed
Snow Angel
Can someone help me tweek this Fix Script? It's not updating the records.
Requirement : Create and run a fix script that will change the Source field value for all existing Security Incidents (active or inactive) currently having a Source field displayed as self_service, so that the field will correctly display Self-service.
source field backend value is "contact_type"
var gr = new GlideRecord('sn_si_incident');
gr.addQuery('contact_type', 'self_service'); gr.query();  while (gr.next())
{gr.contact_type = 'Self-service';   gr.update(); }  gs.print("Fix script execution completed.");
Sandeep Rajput
@Snow Angel Try with the following and see if it works.
while (gr.next()){
gr.contact_type.setDisplayValue('Self-service');
gr.update();
swathisarang98
Hi @Snow Angel ,
while updating you will have to give the backend value of Self- service so try giving gr.contact_type ='self-service'
while (gr.next())
    gr.contact_type = 'self-service';
    gr.update();
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
@Snow Angel  and try  addEncodedQuery instead of addQuery
Sandeep Rajput
while (gr.next()){
gr.update();
Thank you Sandeep! It has worked.
