Flow breaks when the state of catalog tasks are manually changed
sjjantz
I have a flow attached to a Catalog Item which basically flows as noted below. If any of the tasks are manually changed to anything other than "closed complete", it breaks the flow, the fulfillers of this request need the ability to track the state of each task. I need to know how to modify this flow so that it will recognize when the first three catalog tasks all change to "closed complete" so the next approval request can be created.
Trigger: Service catalog
Actions
Get Variables from Catalog Item
Do the following in Parallel
-Ask for manager approval on Requested Item
-Create Catalog Task
If condition - If catalog tasks are complete
then - Ask for approval on Requested Item (different manager)
If condition - if both approvals are approved
Then - Create Catalog Task
If condition - if catalog task is complete
then  - Update RITM/Request Item Records
VaishnaviK3009
Hi @sjjantz ,
I’ve attached my Flow Designer screenshot,please check !!
Screenshot 2026-04-08 110636.pngScreenshot 2026-04-08 110656.pngScreenshot 2026-04-08 110710.pngScreenshot 2026-04-08 110728.pngScreenshot 2026-04-08 110741.pngScreenshot 2026-04-08 110801.png
Mark this as Helpful if it clarifies the issue.
Accept the solution if this answers your question.
Vaishnavi
Technical Consultant
Aditya_hublikar
Hello @sjjantz ,
I have created flow as per your requirement and also created one flow variable to check whether all tasks are closed completed or not .
Please check following screenshots :
5) 6) 7) 8))
Screenshot (21).pngScreenshot (22).pngScreenshot (23).pngScreenshot (24).png
If this helps you then mark it as helpful and accept as solution .
Aditya
AnkaRaoB
Giga Guru
Hi @sjjantz
Instead of using an If condition, the flow should use a Wait for Condition step so it can continuously monitor the status of the Catalog Tasks and proceed only when they are completed.
  1. After creating the Catalog Tasks
Keep your existing parallel structure as it is:
Manager’s Approval
Create Catalog Task 1
Create Catalog Task 2
Create Catalog Task 3
  1. Add a “Wait for Condition” step
Configure the step with the following details:
Table: Catalog Task (sc_task)
Conditions:
Request Item =Trigger -- Request Item
State =Closed Complete
  1. Configure the wait behavior
Set the flow to resume only when:
All matching records meet the condition
This ensures the flow patiently waits until all related Catalog Tasks are completed, even if their states change during processing.
  1. Continue the flow
Once all tasks are in Closed Complete, the flow will resume and proceed with the remaining steps:
Trigger the second approval
Create the next Catalog Task
Update the RITM / Request Item
This approach makes the flow more reliable and prevents it from breaking when tasks are updated manually during the fulfillment process.
