Flow content not visible under Related links, but I have added Flow on "sc_request" table
NaveenkumarA781
Hi Team,
Flow content not visible under Related links in "sc_request" form , but I have added custom Flow on "sc_request table", at the same time Flow also not working properly, my Flow has to Go for Approval once Approver approved then only it should create RITM record, but it Automatically approving, creating RITM record, Please follow attachments for reference
Sandeep Rajput
 There is an OOTB workflow which works on the sc_request table. This workflow might be triggering when your request is getting generated. You need to deactivate this OOTB request workflow first to prevent the auto approvals.
Screenshot 2026-03-10 at 10.02.16 PM.pngScreenshot 2026-03-10 at 10.02.31 PM.pngScreenshot 2026-03-10 at 10.02.36 PM.png
Also, there is no releated links on the request page using which you can access the flow context, to access the context you need to use the flow designer application.
Hope this helps.
