Flow Desginer : JsonParserOperation failed: Empty or null source data (JSON)
pranavi
Hello @pranavi
In the JSON parser step, adapt it based on your fields and values.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this questions from unsolved to solved bucket.
Shivalika
My LinkedIn - https://www.linkedin.com/in/shivalika-gupta-540346194
My youtube - https://youtube.com/playlist?list=PLsHuNzTdkE5Cn4PyS7HdV0Vg8JsfdgQlA&si=0WynLcOwNeEISQCY
pranavi
The same script is working in one instance, but not in another. So should i check on mid-server or azure portal. can you please help me like what the way to check/resolve this issue.
@pranavi
If you are saying the same flow action is working fine in other instance then there is no issue in your JSON parser step etc
Seems you are not able to get the data and hence parser logic is failing
try to add logs and verify
Is input to JSON parser step an output from Powershell? If yes then that could be an issue with mid server and powershell didn't work and it broke the parser step
