08-25-2026 09:20 AM
First time posting - I am looking for guidance how to correctly script a custom short description that shall pull the variable display text values correctly.
The variables: for simplicity renamed to "var1" and "var2"
What I have right now is currently throwing "undefined" errors:
08-25-2026 11:36 PM
Hi @danielalexa ,
If it is a Reference variable, you can use dot-walking to retrieve the display value. Assuming the Requester variable references the User table, you can use:
fd_data._1__get_catalog_variables.requester.name
If it is a Select Box variable, you can dot-walk through the RITM to retrieve the variable's display value. In the example below, we are accessing the RITM through the Flow Trigger and then retrieving the display value of the variable:
fd_data.trigger.request_item.variables.<varname>.getDisplayValue();
If you find this information useful, please mark it as Helpful and Accept the Solution.
Harish
08-25-2026 11:56 PM
Thank you very much Harish, your second statement regarding the select box variable was the correct one here and helped to solve this.
Have a great day - marked as the solution.
Daniel
