‎01-31-2025 01:36 PM
There seems to be an issue with a subflow after the Xanadu upgrade. We use a subflow to Create a Catalog Task consistently, adding variables, Due Date, and other attributes. We input an Assignment Group to that subflow for the task to be assigned to that group. After the Xanadu upgrade, the reference to the Assignment Group looks different. Also, when I try to reference attributes of the Assignment Group in the subflow (name or sysid), it comes back empty
Flows created before upgrade - SysID is used from the Flow Variable to create the task
After upgrade - It attempts to use a string version of the Name + SysID
‎02-01-2025 07:21 AM
Hey Ryan,
Seeing the exact same issue. I do believe it's worthy of a HI ticket. However, as a work-around I've found two options:
- Either change your Subflow Input to a "string" value and pass in just the SysID of the Assignment Group you're looking to use. (Make sure the assignment at the task level is using SysID as well - the system will recognize and fill in the missing details)
- Perform a lookup of the desired Assignment Group before hand and pass the record result into your "Reference" subflow input. This somehow passes the "entire" record, rather than the stringified version.
If you do open a HI ticket - share the results if you can. Hope this help!
Trent
‎01-31-2025 07:57 PM
the assignment group is set with value from flow variable
How is that flow variable assigned value?
share the complete subflow screenshots and also the flow variable step where you are setting the value to it.
Hey Ryan,
Trent
‎04-03-2025 08:58 AM
Ultimately, we did initiate a HI case for this. And there feedback was about the same as this. There is a Problem that ServiceNow has opened to identify a fix for the issue, PRB1861596. But for the time being, we went with the approach to pass the sysid into the subflow as a string.
‎02-05-2025 03:32 AM
Experiencing the exact same thing when calling subflows containing Reference inputs created before Xanadu.
My workaround is performing a lookup of the record and then passing that to the subflow instead of just selecting the record.
