Flow Designer
Options
11-23-2024 04:31 PM
Hi, I could not be select catalog variable: ip_address under the For Each item condition.
Below is the screenshot.
Please help me what is the issue?
Options
11-23-2024 09:38 PM
what did you try so far based on suggestions from other members?
Options
11-24-2024 01:11 AM
Hi @Sarah Bouil ,
You cannot use String type field for ''for each'' condition , strings do not have multiple values to loop or iterate. Hence you will not be able to select string.
you need to change the type of field to be able to select it here...
