Flow is not being Triggered when a record is inserted through Insert Record step in ATF
06-06-2025 04:55 AM
We have an import set Table- Table A. There are no Transform Maps defined, but a Flow will be triggered when a Record is Inserted into Table A.
I created a Insert Record ATF step to Table A, the flow is not being triggered and the Test step is failed with the error-Transform Map not defined.
I dont understand why the flow is not being triggered.Please pour your Insights.
Thank You!
06-06-2025 06:20 AM
what are you trying to test here using ATF?
06-06-2025 06:43 AM
Some Records are imported into Table A and the flow defined on Table A makes some validations and created a record in Target table sc_req_item.
