07-27-2023 08:23 AM - edited 07-27-2023 08:23 AM
Since upgrade to Utah, all our attachments are being encrypted. In Tokyo and before there was a checkbox here to choose to encrypt. That is now gone and none is not the default option.
ServiceNow support says this is OOB, but I can't believe this was intended.
#encryption
#crypto
#attachments
- 20,978 Views
07-27-2023 12:15 PM - edited 07-27-2023 01:51 PM
HI told me to post on community and this was an OOB setting. I spent another 3 hours on it and figured this out --
update the optional_attachment_encrypt UI macro.
OOB config:
Updated:
You also need to comment out these lines:
08-04-2023 07:10 AM
10-18-2023 10:49 AM
Has anyone had a case where attachments do not encrypt if the property com.glide.encryption.enable_attachment_key_ui'. is set to false?
10-20-2023 08:16 AM - edited 10-20-2023 08:17 AM
Additional property:
glide.attachment.encrypt_by_default
Export the XML before you mess with it as it can not be reverted. Check with SN first maybe?
03-27-2024 04:08 PM - edited 03-27-2024 04:08 PM
We tried to update the glide.attachment.encrypt_by_default value to false all ways I could think of, they all failed.
In the end, support needed to set the property directly on the db on our behalf. Can confirm once changed it works!
Files which are attached to tasks i.e. Incidents using drag/drop will no longer be encrypted by default.
04-30-2024 07:58 AM
Update to this -- when you use the REST step in Flow actions and choose Save As Attachment, the files are defaulting to encrypted, despite all the default encryption being turned off per this article. I don't see a way to change this and have a case open with Support on it.
