07-24-2016 07:52 AM
Is there an existing script class I can use to determine if an IP address is in a given CIDR range?
Basically I want to make a call like: isInCIDR(ip_addr, cidr) and it returns true or false. I'd like to do this without first converting CIDR to range and then using SncIPRangeV4 for example.
Or as a corollary, is there a function I can call where given an IP address, it will return the IP Network (cmdb_ci_ip_network) that IP belongs to, regardless if I have that IP address mapped in CMDB.
07-24-2016 05:23 PM
Hi Jason,
Thanks for the inquiry. As far as I know, there's nothing OOB. It sounded like a fun thing to build on a weekend so... here's a script include you can use.
var CidrUtil = Class.create();
CidrUtil.prototype = {
initialize: function() {
ipIsInCidr : function(ip, cidr) {
var cidrIp = cidr.split('/')[0];
var cidrSm = cidr.split('/')[1];
return (this.IPnumber(ip) & this.IPmask(cidrSm)) == this.IPnumber(cidrIp);
IPnumber : function (IPaddress) {
var ip = IPaddress.match(/^(\d+)\.(\d+)\.(\d+)\.(\d+)$/);
if(ip) {
return (+ip[1]<<24) + (+ip[2]<<16) + (+ip[3]<<8) + (+ip[4]);
// else ... ?
return null;
IPmask : function(maskSize) {
return -1<<(32-maskSize);
type: 'CidrUtil'
Here's a small example how it can be used:
var ip = '192.168.1.4';
var cidr = '192.168.1.0/24';
var cu = new CidrUtil();
gs.log(cu.ipIsInCidr(ip, cidr));
08-19-2017 11:56 AM
yes, that's pretty much how I did it earlier. Function I wrote is getIpNetwork(ip) and it returns glide record of matching cmdb_ci_ip_network. I sort the results in ascending order by ip count (custom field) so it will return the most precise subnet defined in IP Networks.
I use that to determine default department assignment for new CI's: if the IP of a new CI is in a network that is 'owned' by a business unit / department, I use that department sourced from cmdb_ci_ip_network for the server ci.
(let me know how you guys are tagging code posts for formatting and I'll include sample).
-j
08-19-2017 04:55 PM
Click on "use advanced editor" then use the double right chevron/arrow button for syntax highlighting.
Sent from my iPhone
11-03-2021 01:37 AM
I took
Also took into consideration
var ipUtil = Class.create();
ipUtil.prototype = {
initialize: function() {},
// convert IP Address to numeric value
IPnumber: function(IPaddress) {
var ip = IPaddress.match(/^(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)$/);
return (ip) ? (+ip[1] << 24) + (+ip[2] << 16) + (+ip[3] << 8) + (+ip[4]) : undefined;
// get un-mask bit from network mask
IPmask: function(maskSize) {
return -1 << (32 - maskSize);
// validate IP Address is member of a network based on id and mask
inNetwork: function(IPaddress, NetworkIDandMask) {
var NetworkID = NetworkIDandMask.split('/')[0];
var NetworkMask = NetworkIDandMask.split('/')[1];
return (this.IPnumber(IPaddress) & this.IPmask(NetworkMask)) == this.IPnumber(NetworkID);
// validate IP Address is between given Start-End IP Addresses
inRange: function(startingIP, endingIP, IP) {
return (this.IPnumber(startingIP) <= this.IPnumber(IP) && this.IPnumber(endingIP) >= this.IPnumber(IP)) ? true : false;
type: 'ipUtil'
//example code _ start
var ip = '192.168.1.256'; // change .256 to a proper octet
var networkid = '192.168.1.0/24';
var network_start = "192.168.1.1";
var network_end = "192.168.1.256"; // change .256 to a proper octet
var cu = new ipUtil();
gs.print("inNetwork: " + cu.inNetwork(ip, networkid));
gs.print("inRange: " + cu.inRange(network_start,network_end,ip));
// example code _ end
01-06-2023 06:15 AM
This code is not working for some situations in my code e.g. ip can be 145.54.0.236/30
01-18-2023 07:37 AM
Good afternoon @Girish Deshpan1 , @Girish Deshpan1 ,
Thank you very much for validating the solution!
I've reviewed the code and made the corresponding adjustments to make it work.
Also added extra functions.
initialize: function () {},
// convert Integer to IP Address
int2ip: function (ipInt) {
return ((ipInt >>> 24) + '.' + (ipInt >> 16 & 255) + '.' + (ipInt >> 8 & 255) + '.' + (ipInt & 255));
// convert IP Address to Integer
ip2int: function (ip) {
return ip.split('.').reduce(function (ipInt, octet) {
return (ipInt << 😎 + parseInt(octet, 10)
}, 0) >>> 0;
// convert Binary to IP Address
bin2ip: function (ipBinary) {
return this.bin2num(ipBinary.slice(0, 8).join('')) + '.' +
this.bin2num(ipBinary.slice(8, 16).join('')) + '.' +
this.bin2num(ipBinary.slice(16, 24).join('')) + '.' +
this.bin2num(ipBinary.slice(24, 32).join(''));
// convert Integer octet to binary
oct2bin: function (oct) {
oct = parseInt(oct);
return "00000000".substr(oct.toString(2).length) + oct.toString(2);
// convert binary to Integer
bin2num: function (bin) {
return parseInt(bin, 2)
IPnumber: function (IPaddress) {
//return (ip) ? (+ip[1] << 24) + (+ip[2] << 16) + (+ip[3] << 😎 + (+ip[4]) : undefined;
return (ip) ? IPaddress.split('.').reduce(function (ipInt, octet) {
}, 0) >>> 0 : undefined;
IPmask: function (mask) {
return -1 << (32 - mask);
// get network information
getNetworkInfo: function (network) {
var NetworkID = network.split('/')[0];
var NetworkMask = network.split('/')[1];
// check format
if (!this.IPnumber(NetworkID) & !this.IPmask(NetworkMask)) {
gs.print('network and mask format is incorrect');
return {};
// iniciate variables
var id, mask, start, end, broadcast;
// set ip octets
var tempIP = (
this.oct2bin(NetworkID.split('.')[0]) +
this.oct2bin(NetworkID.split('.')[1]) +
this.oct2bin(NetworkID.split('.')[2]) +
this.oct2bin(NetworkID.split('.')[3])
).split('').toString();
// set mask as Integer
mask = parseInt(NetworkMask);
// set id as binary array
id = tempIP.split(',');
// set start
start = tempIP.split(',');
// set end
end = tempIP.split(',');
// set broadcast
broadcast = tempIP.split(',');
// set initial values
for (var i = mask; i < id.length; i++) {
id[i] = "0";
start[i] = "0";
broadcast[i] = "1";
end[i] = "1";
// set start
start[31] = "1";
// set end
end[31] = "0";
// build response object
var NetworkInfo = {
'id': this.bin2ip(id),
'mask': mask,
'start': this.bin2ip(start),
'end': this.bin2ip(end),
'broadcast': this.bin2ip(broadcast)
return NetworkInfo;
inRange: function (startIP, endIP, IP) {
return (this.IPnumber(startIP) <= this.IPnumber(IP) && this.IPnumber(endIP) >= this.IPnumber(IP)) ? true : false;
// validate IP Address is member of a network: id, broadcast or range
inNetwork: function (IPaddress, Network) {
return (IPaddress == Network.id || IPaddress == Network.broadcast || this.inRange(Network.start, Network.end, IPaddress)) ? true : false;
type: 'ipUtil'
var ip = '145.54.0.240';
var network = '145.54.0.230/28';
var networkInfo = cu.getNetworkInfo(network);
gs.print('network id = ' + networkInfo.id);
gs.print('network mask = ' + networkInfo.mask);
gs.print('network start = ' + networkInfo.start);
gs.print('network end = ' + networkInfo.end);
gs.print('network broadcast = ' + networkInfo.broadcast);
gs.print("inNetwork: " + cu.inNetwork(ip, networkInfo));
gs.print("inRange: " + cu.inRange(networkInfo.start, networkInfo.end, ip));
