Function to determine if IP is in CIDR network?
jason_lau
Is there an existing script class I can use to determine if an IP address is in a given CIDR range?
Basically I want to make a call like: isInCIDR(ip_addr, cidr) and it returns true or false. I'd like to do this without first converting CIDR to range and then using SncIPRangeV4 for example.
Or as a corollary, is there a function I can call where given an IP address, it will return the IP Network (cmdb_ci_ip_network) that IP belongs to, regardless if I have that IP address mapped in CMDB.
Chuck Tomasi
Hi Jason,
Thanks for the inquiry. As far as I know, there's nothing OOB. It sounded like a fun thing to build on a weekend so... here's a script include you can use.
var CidrUtil = Class.create();
CidrUtil.prototype = {
  initialize: function() {
  ipIsInCidr : function(ip, cidr) {
            var cidrIp = cidr.split('/')[0];
            var cidrSm = cidr.split('/')[1];
            return (this.IPnumber(ip) & this.IPmask(cidrSm)) == this.IPnumber(cidrIp);
  IPnumber : function (IPaddress) {
            var ip = IPaddress.match(/^(\d+)\.(\d+)\.(\d+)\.(\d+)$/);
            if(ip) {
                      return (+ip[1]<<24) + (+ip[2]<<16) + (+ip[3]<<8) + (+ip[4]);
            // else ... ?
            return null;
  IPmask : function(maskSize) {
            return -1<<(32-maskSize);
  type: 'CidrUtil'
Here's a small example how it can be used:
var ip = '192.168.1.4';
var cidr = '192.168.1.0/24';
var cu = new CidrUtil();
gs.log(cu.ipIsInCidr(ip, cidr));
16 REPLIES 16
jonathanriehle
Giga Contributor
Just to add to the above script:
The IP-validation in the 'IPnumber'-function checks for digit.digit.digit.digit .
That check would work for numbers outside the legal ip range though.
E.G.: 10.1.1.1 is a valid ip and gets through. 10.300.300.300 is a non-valid-ip and passes the check as well.
Therefor to tighten the regex replace the
with
var ip = IPaddress.match(/^(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)\.(25[0-5]|2[0-4]\d|1\d\d|[1-9]?\d)$/);
source: https://stackoverflow.com/a/12142961
laurelin
Mega Contributor
Is there anything like this for ipV6?
Our business rules seem to be using an SncIPNetworkV4 library to calculate low/high addresses in a subnet if the address is v4.  But nothing like this is happening for ipv6 addresses.  I can find no documentation whatsoever on the various SncIP* scripts.
Thanks in advance, lauri
