Generate catalog item values in CSV format on submission of catalog item
Angshuman3
Mega Guru
Greetings..!!
I was looking for a solution related to Service Catalog.
We were having a requirement, where we want whatever values we provide on the catalog item form, on clicking on Order Now, the values along with the variable name should get generated in .csv format.
For example,
If there are 2 variable (Name & Age)
and Values entered respectively is (Angshuman & 24)
post this when we click on Order Now, the same information should get generated in .csv format marking Name & Age as to Column names and its values as records entered under each column.
Any leads to this will be very helpful.
Angshuman
Ankur Bawiskar
following script you can add in the workflow attached to the RITM
or have this in after insert business rule on sc_req_item table
give your own file name
this will add a csv file as an attachment to the RITM record
var ritmSysId = current.sys_id;
var set = new GlideappVariablePoolQuestionSet();
set.setRequestID(ritmSysId);
set.load();
var vs = set.getFlatQuestions();
var valuesArray = [];
var csvHeader = [];
for(var i=0;i<vs.size();i++){
var variableLabel = vs.get(i).getLabel();
csvHeader.push(variableLabel.toString());
var variableValue = vs.get(i).getDisplayValue();
valuesArray.push(variableValue.toString());
var csvHeaderRow = csvHeader.toString();
var valueRow =  valuesArray.toString();
var sa = new GlideSysAttachment();
var document = csvHeaderRow + "\n" + valueRow;
var ritmRec = new GlideRecord('sc_req_item');
ritmRec.get(ritmSysId);
sa.write(ritmRec, "data1.csv", "test/csv", document);
Also posted a blog for the same:
https://community.servicenow.com/community?id=community_blog&sys_id=e4f8bd4edbbc881014d6fb243996190e
23 REPLIES 23
Hi Angshuman,
Please find the responses below
1) The Form is a drop down (Option A & Option B). On selection of Option A certain set of variable are displayed and on selection of Option B another set. This is being handled by UI Policy on the catalog item form. But, when the .csv file is generating, it is showing all the variables of both Option A and B. Is it possible to generate the CSV based on the variables those are filled on the form at the time of submission? -> yes this is possible; determine the variable value in script
// put the variable name in these arrays; one array for storing variables which are shown based on value as option A and other for value as option B
var variablesOptionA = ['variable1', 'variable2'];
var variablesOptionB = ['variable3', 'variable4'];
var arrayUtil = new ArrayUtil();
var variableName = vs.get(i).getName();
// put the label here to compare
if(variableLabel != 'Requested By' && variableLabel != 'Opened For'){
if(variableValue == 'Option A' && arrayUtil.contains(variablesOptionA, variableName)))
else if(variableValue == 'Option B' && arrayUtil.contains(variablesOptionB, variableName))){
else{
2) I have 2 variables (Requested By & Opened For) on the form which would be auto populated based on the logged in user. But I don't want this field and its values to come up on the .csv file. Is that possible? -> yes you can handle this in script as below
Try and let me know
Hi Ankur,
The 2nd part is working properly, but the 1st part of the code isn't working properly, it is providing me the same feed file with the empty values.
Please find the below code :-
set.load();
var csvHeader = [];
var regularVariables = ['Application Name', 'Splunk index name', 'Host', 'Environment', 'Log file location', 'Sourcetype'];
var openshiftVariables = ['Application Name', 'Splunk index name', 'Openshisft Namespace name'];
if(variableLabel != 'Requested For' && variableLabel != 'Opened By'){
if(variableValue == ('Regular new application logs onboarding' && arrayUtil.contains(regularVariables, variableName))){
else if(variableValue == ('Openshift logs onboarding' && arrayUtil.contains(openshiftVariables, variableName))){
else{
sa.write(ritmRec, "splunk.csv", "test/csv", document);
Angshuman
Hi Ankur,
Did you get time to check my code?
Please if possible do let me know once you get hold of what I am doing wrong.
Angshuman
Hi Angshuman,
Can you update the line as below and test once
there was a round bracket just before the variable name and also at the end after arrayutil contains method; I have removed that from if and the else statement
you need to check the variable label is present in the array or not and not the variableValue since in the array you have put the variable labels
updated code below
if(variableLabel == 'Regular new application logs onboarding' && arrayUtil.contains(regularVariables, variableLabel)){
else if(variableLabel == 'Openshift logs onboarding' && arrayUtil.contains(openshiftVariables, variableLabel)){
else{
Hi Ankur,
I did make the changes based on your code, yet when the feed file is being generated it is coming with empty values and the Variable Labels of those fields which we haven't selected while creating the Request.
set.load();
var csvHeader = [];
var regularVariables = ['Application Name', 'Splunk Index name', 'Host', 'Log Location', 'Environment', 'Source Types', 'Please enter keywords for your logs for tagging purpose', 'Is there any sensitive information in your logs?', 'Please enter a description and usage of the logs you are onboarding to Splunk', 'What do you intend to use Splunk for with the logs you are ingesting?'];
var openshiftVariables = ['Application Name', 'Splunk Index name', 'Openshisft Namespace name', 'Please enter keywords for your logs for tagging purpose', 'Is there any sensitive information in your logs?', 'Please enter a description and usage of the logs you are onboarding to Splunk', 'What do you intend to use Splunk for with the logs you are ingesting?'];
	if(variableLabel != 'Requested For' && variableLabel != 'Opened By' && variableLabel != 'Splunk Application'){
		else{
The Output I am getting:-
Angshuman
