GlideRecord-Query with OR-Condition (Client-Script)
jens_sn
I try to do a query in a client-script with an or-condition. What I would like to achieve:
Query the Configuration Items of a Caller.
When I execute the script as background-script it works. But when I try to execute it as client-script I get the error that the variable (qc2) is an undefined function...
Here ´s my example code (which I excute as background script):
var newValue = 'a4425491880d2400ad10795120f63dd5' // Test-Value (Caller_id)
var gr = new GlideRecord('cmdb_ci');
var qc1 = gr.addQuery('owned_by',newValue); // Query by Caller
var qc2 = gr.addQuery('name', 'STARTSWITH', 'Notebook') // Condition1
qc2.addOrCondition('name', 'STARTSWITH', 'PC'); // Condition2
while (gr.next()){
if(gr.ip_address != ''){
gs.log(gr.name); // Test for Background-Script
alert(gr.name); // Test in Incident-Module
Does anybody know what ´s wrong?
benlittle
Harkening back to high school math, DeMorgans law says you can always write ORs as ANDs and vice versa. The simple rule is
1) replace each condition with a single variable
2) Invert each element
3) Swap the operator
4) Invert the whole thing
5) Put back each condition
Take for example the following that you want to achieve:
country = France OR country = USA
let p replace 'country = France'
let q replace 'country = USA'
Step 1 - replace with a single variable --> p OR q
Step 2 - invert each element --> !p OR !q
Step 3 - Swap the operator --> !p AND !q
Step 4 - Invert the whole thing --> ! (!p AND !q)
Step 5 - Put back your conditions --> ! (Country != France AND Country != USA)
Simple translation in javascript:
! ( p || q ) == ( !p && !q )
Just make sure that when you 'invert' the operator, you know what the inversion is.
== inverted is !=
> inverted is <=
< inverted is >=
It obviously doesn't work with substring checks like STARTSWITH, but works when you can invert the operator.
