Hiding fields on portal using Client Script
AndriaLynG
Good day!
I created a catalog client script that hide fields if the requested for is member of a group and selected specific request type. It works on the portal, but an issue encountered while changing the requested for field. Can someone know how to configure or fix the script for this? Thanks!
Amitlokre
Mega Guru
  1. You’re using an onChange client script on the request_type variable.
    function onChange() { var deptId = g_form.getValue('requested_for_entity'); var requestType = g_form.getDisplayValue('request_type'); ... }
     This script only runs when request_type changes.
    But when you change Requested for, the script doesn’t automatically re-run, so the visibility rules for your fields don’t update.
    Fix :
  2. Create another onChange Client Script for the variable requested for.
  3. Inside that script, call the same logic you already have (e.g., put your hide/show logic into a reusable
16 REPLIES 16
SunilKumar_P
@AndriaLynG - As you mentioned "but an issue encountered while changing the requested for field", do you have any client scripts related to 'reqeuested for' variable? If yes, could you please share?
I only created client script for the variable 'requested_for_entity' and 'request_type'.
