How are UI Policy Conditions and UI Policy Actions decided in real-time ServiceNow projects?
BURLED
Hi Everyone,
I am currently learning UI Policies in ServiceNow and have a few questions about how they are implemented in real-time projects.
For example, when configuring a UI Policy for Incident, Problem, or Change Request tables:
  1. In real-time projects, does the client or Business Analyst provide the exact UI Policy requirements and conditions through User Stories or business requirements?
  2. As a ServiceNow Developer/Admin, do we analyze the requirements and independently decide which conditions to configure, such as Assignment Group is not empty, State is Resolved, etc.?
  3. While configuring UI Policy Actions, do we select only the existing fields from the respective table and configure them as Mandatory, Read-only, or Visible based on the requirements?
  4. If a client requires a new field, should we create that field separately in the table before configuring the UI Policy Action?
  5. Do developers generally receive detailed step-by-step instructions, or are we expected to understand the business requirement and design the UI Policy configuration ourselves?
I would appreciate it if experienced ServiceNow professionals could share how this process works in real-time projects.
Thank you!
Best Regards,
Damodar.
3 ACCEPTED SOLUTIONS
MahathiVeeR
Hello Damodar,
In real-time projects, UI Policies are generally configured based on the client's business requirements. The Business Analyst or client usually explains the expected behaviour, and as a ServiceNow Developer/Admin, we analyse those requirements and implement the appropriate conditions and actions.
One important thing to understand is that ServiceNow already provides many functionalities OOB (Out of the Box), so we don't necessarily need to create UI Policies for everything. We first check whether the required functionality is already available through existing configurations.
Catalog UI Policies are also commonly used because they help control the behaviour of variables on catalog items, such as making fields mandatory, read-only, or visible based on user selections.If a new field or variable is required, we create it first and then configure the relevant UI Policy or UI Policy Action.
Developers are not always given step-by-step configuration instructions. We are generally expected to understand the business requirements, explore the existing OOB functionality, and decide the best way to implement the requirement.
Hope this answers your question!
My suggestion would be to practise different real-time use cases using both Normal UI Policies and Catalog UI Policies. There are plenty of tutorial videos available online covering practical scenarios.
Try practising scenarios involving Incident, Problem, and Change Request forms, as well as Service Catalog items and variables. First understand the business requirement and then try implementing the solution yourself.
The more you practise with real-time scenarios, the more confident you will become. It will also make your ServiceNow learning journey more interesting!
If you found this explanation helpful and it answered your question, please consider marking it as helpful. It would be much appreciated!
Happy Learning! 😊
Rakesh Giri
In real-time ServiceNow implementations, you will receive Business Requirements or User Stories directly from the Business Analyst (BA) or product owner. These requirements are strictly functional, meaning they explain what the business wants to happen, not how to build it technically.
As a ServiceNow Developer, you are expected to analyze these requirements and independently choose the best technical solution—whether that is a UI Policy, Client Script, or Business Rule—while strictly following platform best practices. Nobody will provide step-by-step instructions or tell you which fields to configure.
Kindly take the ServiceNow System Administrator course if you haven't already! It covers and explains the core details about these topics—including the data dictionary, UI configurations, and client vs. server-side logic. It will help you deeply understand how all of these pieces connect in real-time projects.
All the best!!!
Tejas Adhalrao
hi @BURLED ,
In real-time projects, the Business Analyst or client usually provides the business requirement through user stories or functional specifications. They may not always provide the exact UI Policy conditions.
As a ServiceNow Developer, your responsibility is to understand the requirement and translate it into UI Policy conditions and actions.
For example, if the requirement says a Resolution Code must be mandatory when an Incident is Resolved, you configure the condition as State is Resolved and the UI Policy Action to make Resolution Code mandatory.
If a new field is required, create the field on the appropriate table first, then configure the UI Policy Action for it.
You are generally expected to understand the business requirement and design the configuration. You may need to clarify the expected behavior with the BA or client rather than assume the conditions yourself.
In short, the requirement defines what should happen; the developer decides how to implement it using UI Policies or other suitable platform features.
If this helped, mark it helpful and accept the solution.
Tejas
BURLED
thank you for your clearly explation
