How remove selected values from a list collector
Hari1
I have a requirement to remove list collector selected values if we selection is more than 3 values.
I should be able to enter the 4th value the list collector should not accept the 4th value when the user enters beyond 3 values. It should remove the additional selected value. I am try to achieve this using the onChange - Client Script. Can this be achieved?
Gunjan Kiratkar
Hi @Hari1 ,
You Can use below onChange client script for that :-
    var values = g_form.getValue('work_notes_list').toString().split(',');
    //g_form.addInfoMessage('total value in users '  + values);
    if (values.length > 3) {
        alert('Please select only 3 choices');
        //g_form.removeOption('who_are_need_to_access','value');
        for (var i = 0; i < 3; i++) {
            g_form.setValue('work_notes_list', values[i]);
        return values;
 Replace your field wherever 'work_notes_list' is written.
You can try the below code in onChange Client Script;
//Type appropriate comment here, and begin script
var values = g_form.getValue('variable_name').toString().split(',');
if(values.length > 3){
alert('You can select only 3 choices');
g_form.clearValue('choose_your_favourite');
Karthik R
Muhammad Khan
Add the below attribute to your list collector variable.
glide_list=true
Adding above attribute to make it look like a list field, this might help to avoid auto sorting of selected values to ensure that none from the first 3 selected values get removed.
After that use onchange catalog client script on your list collector variable.
    var appCount = g_form.getValue('applications_to_be_updates_is_more_than_5');
	var arr = newValue.split(',');
    if (appCount == 'Yes' && arr.length > 3) {
        alert("You cannot add more than 3 applications");
		g_form.setValue('select_the_application_name', arr.slice(0, -1));
