How to build the connection between oauth authentication and scripted Rest API
Ramanjaneyulu
When we are working on inbound integration we build the scripted Rest API.
Is there any ServiceNow existing relation between oauth authentication between scripted Rest API?
I did not see any direct relation to point the oauth authentication from scripted rest api.
How to build the connection between oauth authentication and scripted Rest API?
example :
If third party application team hit the oauth endpoint they will get token and the same token they will use in the header and trigger the main endpoint with payload.
I am doubting if thirdpty team does not follow the process if they are trying hit main endpoint by using basic credentials ( which will provide to access the token api) without token.
even though the ServiceNow is allowed for operation from scripted rest API.
I know there are some ACL's available in scripted REST API but, that will only can be restricted by role base.
It can't check if the inbound call is using token or not.
Appreciate for your response:)
Thanks & Regards,
Ramanjaneyulu.
2 ACCEPTED SOLUTIONS
Ademir Amaral1
Using basic authentication - providing your account credentials with every request - is inherently insecure. In this video we look at how to enable authentication to our API using OAuth, that is, using temporary access tokens. This video demonstrates only one authentication flow for issuing access
Randheer Singh
Hi @Ramanjaneyulu ,
You should use the REST API access policy and REST API Auth scope feature. Jason's Video on this topic is an excellent resource for learning about it.
Randheer
Ademir Amaral1
Hi @Ramanjaneyulu
Take a look at this video, it helped me a lot:
https://www.youtube.com/watch?v=gqqA99rKBJU
Hi Ademir,
Thanks a lot for your response!!!
Yeah you are these the YouTube link are very useful.
Just wanted to correct link address.
For my question it would be applicable for part 17.
https://youtu.be/W7VgnaVFmOw?si=GiQULLFnMEvVGPvu
Randheer Singh
Hi @Ramanjaneyulu ,
Randheer
Hi @Randheer Singh
Thanks a lot for quick response.
Really appreciated 🙂
