how to capture dashboard in update set and move to UAT/Prod
satya30
I created a dashboard in DEV. I would like to capture and move it to UAT. Any help on how to do?
Thank you.
Prathmeshda
Hello @satya30
To move a dashboard created in DEV to UAT, you must capture it in an Update Set and promote it.
Prerequisites
  • Access to both DEV and UAT instances
  • Update Set migration permissions
  • All related components (reports, widgets, indicators) must exist or be included
Steps to Capture and Move the Dashboard
Create or Select an Update Set (DEV)
  • Navigate to System Update Sets > Local Update Sets
  • Create a new Update Set (or select an existing one)
  • Set it as Current
 Capture the Dashboard
  • Navigate to the dashboard you want to migrate
  • Open the dashboard Properties
  • Click Add to Update Set
    (This captures the sys_dashboard record)
Ensure the following are also captured in the same Update Set:
  • Reports used in the dashboard
  • Performance Analytics widgets (if applicable)
  • UI Pages or Widgets (if custom)
Review the Update Set
  • Go to System Update Sets > Local Update Sets
  • Open your Update Set
  • Verify all required records are included
Move Update Set to UAT
  • Mark the Update Set as Complete
  • Navigate to Retrieved Update Sets in UAT
  • Retrieve the Update Set from DEV
  • Preview the Update Set
  • Resolve any errors or missing dependencies
  • Commit the Update Set
Validate in UAT
  • Navigate to the dashboard in UAT
  • Confirm all widgets and reports load correctly
  • Validate user roles and permissions
    If this response proves useful, please mark it as Accept as Solution and Helpful. Doing so benefits both the community and me. 👍🙂
