How to create a dashboard with 2 reports
sinu2
I got an requirement , to create a dash board with 2 reports
1.would like to see a daily trend of incoming request
2.and the average turn around time.
how can i do this
9 REPLIES 9
While i am creating report in the CONFIGURE section I am not able to see all the options that in your image showing.
WHat should be the TYPE i need to select?
For the first report Type should be column and for second Type is List
Thanks a lot for the reply after your suggestion i kept type. But i need to grab business duration field in my second report how can i get
Hi @sinu2 ,
You can get that from Configure -> Choose Column -> select the field Business Duration (move it towards right and save it )
Please check and Mark Helpful and Correct if it really helps you.
Swathi Sarang
But the configure should be done on form level right?
ANd also now one more question, client confirmed that they need on sc_request table
1. Average turn around time
