How to create a link in popup using client script in Service Portal
Hiranmayee Moha
Hi @ Ankur Bawaskar!
If the user selects 'Yes' from choice list of a catalog item, a popup will show with a link that says, Please raise a request to "XYZ Software".
The code is attached below:
   var yes = g_form.getValue('variable');
 if (yes) {
    var Url = 'link';
g_form.addInfoMessage("Please raise a request to 'xyz Software' in the catalog: <a href='" + Url + "'</a>");
TIA
Hiranmayee Mohanta
4 ACCEPTED SOLUTIONS
Ankur Bawiskar
@Hiranmayee Moha
something like this will show link in portal
Ensure you give correct URL
    var yes = g_form.getValue('variableName'); // give the variable name here
    if (yes == 'yes') { // give the value you want to compare
        var urlString = '<p><a class="web" target="_blank" href="' + "/esc" + '">' + "Click Here" + '</a></p>';
        g_form.addInfoMessage("Please raise a request to 'xyz Software' in the catalog:" + urlString);
SumanthDosapati
@Hiranmayee Moha
Try below approach
var link = '<a href="google.com">URL</a>';
var message = 'Please raise a request to xyz software in the catalog' + ' ' + link + ' ';
gs.addInfoMessage(message);
Accept the solution and mark as helpful if it does, to benefit future readers.
Sumanth
@Hiranmayee Moha
My mistake, gs wont work in client scripts.
use g_form.addInfoMessage.
Hi @Ankur Bawiskar !
It worked. I had done a small mistake.
Thanks again
Hiranmayee Mohanta
18 REPLIES 18
Hi @SumanthDosapati !
Thanks for your prompt and proactive response. The code you shared is working as expected; however, the environment doesn’t seem to be functioning properly in that browser.
Please find the attached code below.
var req = g_form.getValue('variable Name');
    if (req == '1') {
        var urlString = '<p><a class="web" target="_blank" href="' + "/esc" + '">' + "google.com" + '</a></p>';
 g_form.addInfoMessage("Please raise a request to 'XYZ Software' in the catalog:" + urlString);
    var fields = g_form.getEditableFields();
    for (var x = 0; x < fields.length; x++) {
    g_form.clearValue(fields[x]);
what do you mean by 'doesn’t seem to be functioning properly in that browser.'
Hi, after resetting the catalog item’s fields to null, the instance becomes unresponsive in that browser for a few minutes. During this time, other modules and applications also fail to open.
The code below is working as expected. The instance remains responsive, and other modules and applications are loading and functioning properly.
var fieldsToClear = ['field1', 'field2', 'field3']; // replace with actual variable names
fieldsToClear.forEach(function(field) {
g_form.clearValue(field);
Likely Cause:
Clearing all editable fields in a single operation, especially in forms with many fields or dependent client scripts, can cause the browser to:
  • Re-trigger multiple onChange client scripts.
  • Overload the client-side processing.
  • Introduce rendering delays, especially if there are UI policies, catalog client scripts, or dependent reference fields that react to those changes.
This leads to high client-side resource usage, making the instance appear unresponsive.
Thanks again for your help!
Hiranmayee Mohanta
SumanthDosapati
@Hiranmayee Moha
Try below approach
Sumanth
