How to Create a Switch in Flow Designer
Pak
Giga Contributor
New to flow designer. First time trying to create some sort of switch. I have checkboxes on the request form. They can multi-select the checkboxes, but they need to route to different teams depending. So I will need some kind of join to have it wait for all the Catalog Tasks to be done before closing.
What's the best and easy way to handle this?
Ujjawal Vishnoi
Either use the make a decision logic or use multiple If statements depending on the amount of logic required.
Hope it helps.
Ok thanks. I will look into decision logic.
Sure Pak. If i could help you to resolve your issue then please mark this answer correct and helpful and if you have any other issue then let me know.
Hi @Pak
Thank you for marking my response helpful.
If I helped you to resolve your query with my answer. Then I would really appreciate if you can mark my answer correct and helpful. So that it can be moved to answered list and helpful for future readers.
Ujjawal
