How to Display Knowledge on Portal
gazalagrawa
I have created a knowledge base and linked the category as well with the portal. But I am not able to view the category or article on the portal. The page used on portal is OOB page kb_view2. How to fix this? Does the page or widget are tied with category somewhere? I am not able to troubleshoot this
I checked and I have access to the article.
Dinesh_Now
  • Check User Criteria
  • Go to Knowledge → Administration → Knowledge Bases
  • Open KB
  • Check Can Read
  • Add Everyone for testing
    Please refer this if it can help. i tried my best to help. not sure can help this to your question.
    If this address your question, please don't forget to mark this response correct by clicking on Accept as Solution and/or Kudos.
    You may mark this helpful as well if it helps you.
