How to get first character in a name.
User267
This are two fields in catalogue form.
PH last name- Mary
Check digit- when you entered something in field"PH last name" then the starting ( First character) letter of name will.
Riya Verma
Hi @User267 ,
Hope you are doing great.
Create on change client script on last name field and try usig below script in onchange function:
  var lastnameField = g_form.getValue('lastname');
  if (lastnameField.length > 0) {
    var firstCharacter = newValue.charAt(0);
    g_form.setValue('check_digit', firstCharacter);
    g_form.clearValue('check_digit');
Please mark the appropriate response as correct answer and helpful, This may help other community users to follow correct solution.
Riya Verma
11 REPLIES 11
Thank you so much
OlaN
Tera Sage
What is the purpose of the "Check digit" field?
If it always should contain the first letter of another field value, there is not really any need to create a input field for check digit, since the user should never fill out this field.
You can extract the value after the form has been filled out, without the additional variable.
Providing example on how to extract the first character from a variable with Flow designer.
