How to hide choices from choice list using client script onchange
swathigangadhar
How to hide choices from choice list using client script onchange, i want to hide few choices in subcategories when category is changed, i tried using g_form.removeOption('subcategory', '7'); but no luck, how to solve this?
16 REPLIES 16
If your using subcategory as dependent field to category,you have to uncheck that. that;s the reason it is not removing when I tested in personal dev. i unchecked dependent field on subcategory and this code is wrkg fine
var getCategory = g_form.getValue('category');
  alert(getCategory);
  if(getCategory=='software')
  alert('insde');
  g_form.removeOption('subcategory','os');
Harish
I want both functionalities.
I have same requirement with you, have you resolved your problem?
If you solved your problem, could you share with your solution?
Hi Swathi,
Did you get the solution? If yes, can you please post it here.
Dedeepya
