How to import users, roles and group
manjusha
Hello all,
I want to import users roles and group from excel sheet into service now users , roles and group
table.
Please give me the brief description for how to achieve this.
Manjusha
trytolearn
Kilo Explorer
I just created a custom table and the user doesn't see the import link on the menu.  How can I give the user permission to import?
You'd want to address this within the System UI > UI Context Menu, and look for Export. You can create a custom role, give that to the user, then set condition to allow for that user to export or specifically address a certain type of export: like...XML only, etc.
You may need to copy that same export code and assign to your custom table if it doesn't show up by itself, since OOB it's for global.
Please mark reply as Helpful, if applicable. Thanks!
