How to include record producer variables into Incident Description field
Renu9
I m using record producer to create an Incident record.
There are 4 variables in my record producer where I need to include all these variable questions with answers into the Incident record Description field.
Could you please guide me how can this be achieved?
Variables in Record producer:
1. Date of issue
2.Time of Issue
3.How many users affected
4. Required Information
I want the description field to appear in the Incident form something like this:
Below are the details
1. Date of issue : 17-10-2023
2.Time of Issue: 10 CET
3.How many users affected: 2
4. Required Information : Test
2 ACCEPTED SOLUTIONS
Jaspal Singh
Mega Patron
Hi Renu,
In the Record producer for the Incident you can try adding something as below to the Entitlement script
var dateis=producer.date_of_issue;//replace the variabledate_of_issue name accordingly
var timeis=producer.tiem_of_isse;//replace the variable time_of_issue name accordingly
//so and and so forth for other variables
current.description=dateis+' '+timeis;
Harsh_Deep
Hi @Renu9 ,
In the Record producer for the Incident you can try adding below script in producer script
var date=producer.date_of_issue;//replace the variabledate_of_issue name accordingly
var time=producer.time_of_isse;//replace the variable time_of_issue name accordingly
var affectedUsers=producer.how_many_users_affected;//replace the variable how_many_users_affected name accordingly
var requiredInfo=producer.required_information;//replace the variable required_information name accordingly
current.description=date+' '+time+' '+affectedUsers+' '+requiredInfo;
Please be sure to bookmark this article as well as mark it as Helpful if you thought it was helpful.
swathisarang98
Hi @Renu9 ,
You can write the below code in the record producer script,
var date=producer.u_date; //"producer.<backend name>"  please add your field backend name (for all 4 fields)
var time=producer.u_time;
var userAffected=producer.useraffected;
var requiredInfo=producer.info;
current.description ='1.Date of issue : '+date+'\n 2.Time of Issue: '+time+'\n 3.How many users affected: '+userAffected+'\n 4.Required Information : '+requiredInfo;
Output:
Please check and Mark Helpful and Correct if it really helps you.
Swathi Sarang
