How to make character limit max 1000 in Multi Line text variable.
‎07-26-2022 08:05 AM
I want to set character limit maximum 1000 on one Multi Line text variable. I have used max_length=1000 in variable attribute but it didn't worked. I have also used one client script found on community that also didn't worked. It is just showing the error message when limit crossed 1000 but I want to restrict user when it crossed 1000.
User should not be able to type more that 1000 char.
Please suggest on this . Thanks in advance!
‎04-10-2024 04:28 PM
The URL behind your link is invalid.
‎04-11-2024 04:21 AM
Then go and complain by the people taking the page down. Are you really going through 2 year old posts and then start complaining on every post with a link that was valid 2 years ago, that it's no longer valid? If you are looking for an answer to the same question, raise it yourself to get valid links (or do a Google search yourself).
When providing a link with a solution, the link is valid, until the company or person behind the link takes it down.
‎04-11-2024 04:08 PM
I'm just providing you some information. Your projection about what I'm doing or not doing isn't helpful and neither is any other part of your response.
‎04-11-2024 05:01 PM
Hello Paul,
I would suggest creating a new question instead of replying to old ones. However max_length is only available for single-line and wide single-line text boxes.
