How to restrict max length of characters, on a Catalog Form field, based on a dependent field ?
AbdurRahmanSnow
Good evening
On a Catalog form, based on Country is Thailand, then it should allow the below 3 Address line Fields to only take 70 characters/digit length.
How can I do this? Please guide.
AbdurRahmanSnow
Correct Answer
function
onSubmit() {
   var country = g_form.getDisplayValue('country');
   if (country == 'THAILAND') {
      var add1 = g_form.getValue('Address1');
      var add2 = g_form.getValue('Address2');
      var add3 = g_form.getValue('Address3');
      //alert('Address lengths: ' + add1.length + ', ' + add2.length + ', ' + add3.length);
      if ((add1.length > 70) || (add2.length > 70) || (add3.length > 70)) {
        alert('The maximum character limit for addresses in Thailand is 70.!');
        return false;
   return true;
13 REPLIES 13
Dr Atul - LNG
I am not an expert in coding, but something
If Country = xx
Then
Value some things.
Harrymate
You can enforce this character limit restriction dynamically using Client Scripts:
using Client Scripts >>  Go to the Catalog Client Scripts >> Click New
in there Type should be onChange and pass the Variable Name country (Make sure this matches your Country field variable name)
 // Check if Country is Thailand
    if (newValue === "Thailand") {
        // Define Address Field values
        var addressValues = ["address_line_1", "address_line_2", "address_line_3"];
        addressValues.forEach(function(field) {
            var addressField = g_form.getControl(field);
            if (addressField) {
                // Set Maximum Length to 70
                addressField.maxLength = 70;
                g_form.showFieldMsg(field, "Maximum 70 characters allowed for Thailand.", "info");
        // Remove field restriction if not Thailand
            if (addressField) {
                addressField.removeAttribute("maxLength");
                g_form.clearMessages();
Thanks a lot Harry. I just modified and got the code as below:
Correct Answer
function onSubmit() {
        return false;
   return true;
AbdurRahmanSnow
Correct Answer
function
onSubmit() {
        return false;
   return true;
