How to send a mail to servicenow outside vendors using flow designer
‎09-19-2023 03:16 AM
How to send mail to servicenow outside vendors using flow designer. Email has to be sent to outside vendor as part of flow.
‎09-19-2023 04:03 AM
Hi @User_267
You can create a flow Action with email step and call the action in flows. Find the screenshot below.
If my response helps to solve your issue, kindly mark it as helpful & correct.
‎09-19-2023 05:13 AM
outside vendor profile won't be in servicenow, so in To: if i select that person mail, then the vendor is not receiving any mails.
‎09-19-2023 06:15 AM
May I know which instance it is Prod or Non Prod?
If it is non-prod outgoing may be disabled by default.
‎09-19-2023 06:16 AM
It's my personal PDI and i enabled, email sending option
