How to set a view as default for all users
reachjake
I have created an new view for the Change form and would like it to be the default view for all ITIL users. How would I achieve this?
Thank you
13 REPLIES 13
That is what I needed to know to set the default view.
Can I ask how to learnt these, is there an online resource or course?
Thank you for your help.
Go to System UI - View Rules
create a new rules, put condition like if your_customized_table, then your_customized_view.
this way, all users actions on that table will have your customized view as default
Hi @jamieliao ,
How do you set customised_view on the customised_table based on Catalog item submitted?
For example, the agent would view different default view if someone submit new account creation than normal incident on the catalog item table.
pawan k singh
You can create a view Rule like below. This will set default view like "Major Incidents" is default view here for all the Incidents, including the new Incident we create.find_real_file.png
Please mark this answer correct, if it helped you!
Pawan K Singh
