How to trigger Flow yearly basis ?
Mahesh23
Hello community,
Is this possible to trigger flow yearly basis ?
For example : Flow should trigger on Jan 1 at 12 PM every year.
Well then you create a Flow variable, run the script in Set Flow Variables and then use that in the IF statement.
Use a true false flow variable and the return a true or a false variable.
Ajay_Chavan
Yes, use a Scheduled Flow Trigger:
Steps:
Flow Designer → New → Flow
Add Trigger → Scheduled
Configure Schedule:
Run: Yearly
Timezone: Select appropriate timezone
Start Date/Time: January 1, 12:00 PM
Repeat: Every 1 year(s)
Alternative - Advanced Scheduling: If you need more control, use Daily trigger with condition:
Run: Daily at 12:00 PM
Add Flow Logic: Check if current date is January 1st
// In a Script step
if (gs.nowDateTime().getMonthLocalTime() == 1 &&
    gs.nowDateTime().getDayOfMonthLocalTime() == 1) {
    // Continue flow execution
    return true;
// Exit flow
return false;
Scheduled Job Alternative: Create a Scheduled Job (System Definition > Scheduled Jobs):
Run: Yearly
Script: Trigger your flow via direct execution
Recommendation: Use the native Scheduled Flow Trigger with yearly recurrence - it's the simplest and most maintainable approach.
