How to write a script section in USER CRITERIA for access to knowledge base;
ganesh68
I have a article A in my knowledge base. User with a group X. shouldnt have access to the KB article A.
I have written script for the same. Can some one help me whats the issue ?
var gr = new GlideRecord('sys_user_grmember');
gr.addQuery('user', 'user_id');
gr.addQuery('group', '<Sys id of group name>');
if (gr.next()) {
gs.info("User is Member of Group! requester");
answer= true;
gs.info("User is Not a Member of Group!");
answer= false;
this code is not working it seems.
Good one, nice that you shared. Didn't notice before.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
asifnoor
if user_id is a variable, then do not use single quotes.
var user_id=gs.getUserID();
gr.addQuery('user', user_id);
if (gr.next()) {
answer= true;
answer= false;
Alternatively you can try like this
if(gs.getUser().isMemberOf("group name")) {
answer= true;
answer= false;
Mark the comment as correct/helpful if it helps to solve the problem.
Hello Ganesh
Let me know if this has answered the question or if you are still facing any issue.
Ganesh mentioned not wanting to use gs.getUserID();
Also this should not be necessary, as the User Criteria already contains user_id by default as variable.
The Docs page also mentions this. I actually didn't knew, though good point from Ganesh.
Kind regards,
Mark
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Aha. Just went through the thread and the link. Got it.
so just removing the quotes (as I have mentioned in my script) from the user_id variable in the query should be enough.
