How work Max Length for String fields when importing data
shun6
Hi all,
I have a question about max length for string field.
I tried to input data to the below field by System Import Sets > Load data
[Target field]
u_company_name_short
Max length : 16
At Instance A,  >16 character can be imported, but at Instance B accept maximum 16 charecter.
Can anyone explain why this happen??
I also check inportset table's max length and there are no deferennces in both instance.
Thanks.
abbasshaik4
Tera Sage
Hello @shun6,
Please refer to the below link:
https://www.servicenow.com/community/developer-forum/the-maximum-field-length-in-the-imported-set-ta...
Mark my correct and helpful, if it is helpful and please hit the thumbs-up button to mark it as the correct solution.
Thanks & Regards,
Abbas Shaik
