02-01-2025 12:17 AM
i am trying to create a consumable asset in the alm_consumable asset table but it is not populating correctly . as on the catalog item form , i have set a drop down list for the stock room and the catalog as reference .
Walk-Up Experience
02-02-2025 12:25 AM
@Ankur Bawiskar i found my answer which i was going in the wrong direction
i used this table with reference and it worked : cmdb_consumable_product_model
02-01-2025 05:39 AM - edited 02-01-2025 05:39 AM
02-01-2025 06:39 AM
@Ankur Bawiskar i tried to use this : var result =return fd_data.trigger.request_item.variables.<variable name>.getDisplayValue();
return result;
still does not work
02-01-2025 07:14 AM
any before insert business rule which is clearing that field?
Did you try making that variable as reference instead of lookup select box?
02-01-2025 04:43 PM
02-01-2025 07:32 PM
that's a data issue which you need to identify why 2 records have same name
Did you select any stockroom and submit and see if the field got updated?
