I need to pass dynamic and static both the values in my flow.
07-18-2023 10:41 AM
In my organization, we build a functionality to pass json_input to flow which will update the RITM Field.
So we pass like this:
"sys_db_object": "sc_req_item",
"assignment_group": "2830c02fdbd64150574073e3f39619b1",
"u_service_instance": "current.variables.choose_application_service"
So this will update the assignment group and application service on RITM.
But I wanted to print the dynamic and static both the values.
Like if we want to print short description where I will take some static data from RITM form and some dynamic data from variables values filled in Catalog.
Like This:
"u_service_instance": "current.variables.choose_application_service",
"short_description":"current.item.name, - ,current.variables.choose_permission.display_value"
Can you pls suggest some ways, how we can achieve this.
07-18-2023 11:27 AM
@pandeyved You can write it as below, You can use variable name as is.
"u_service_instance": current.variables.choose_application_service,
"short_description": current.item.name + ' - ' +current.variables.choose_permission.display_value,
If above doesn't work then try below, adding toString() method to get output in string format
"u_service_instance": current.variables.choose_application_service.toString(),
"short_description": current.item.name.toString() + ' - ' +current.variables.choose_permission.display_value.toString(),
07-18-2023 11:34 AM
Hi @SANDEEP28
I tried this, but it is returning undefined.
07-18-2023 10:36 PM
@pandeyved Are you passing this json input from business rule ? Also try printing below variables to see whether it contains value or not before passing to flow
Have you tried .toString() also? Share some screenshots here
current.item.name
