in client script what is inherited and isolated script
satish samrat
in client script what is inherited and isolated script, what is the purpose and for what mainly we use it?
Raghu Ram Y
Hi @satish samrat
Inherit : For example, a client script on the task table can be inherited to tables that extend it, like the incident, change, and problem tables. To allow tables to inherit a client script, the inherit checkbox must be set.
Isolate: Client-scripts will run in strict mode, with direct DOM access disabled so access to jQuery, prototype and the window object are likewise disabled. so if you want to access any DOM object in such scenarios you need to make it "true/false"
I hope it helps you, if so please mark my response as correct and helpful.
Raghu Ram Y
Hi @satish samrat
Kailash Bhange
Please review below Article for Client Script details and mark helpful if it helps you.
World of Client-side Scripts: #1
Thank you!
Kailash Bhange
LinkedIn
