Incident autoclosure in 5 Business days
Marcin Witosla1
Hello ,
Is there a working solution to autoclose incidents after 5 business days excluding weekends and holidays?
I have searched other community topics but any of them not working
The best solution is to created a scheduled job fired daily and checking incidents resolved at date.
Any ideas?
Marcin
Ankur Bawiskar
@Marcin Witoslawski
You will have to check whether the current date is more than 5 business days of the updated time of the INC
// This script automatically closes incidents that are resolved
// and haven't been updated in the specified number of days.
// This number is a property in System Properties.
// To place a comment in the incident, uncomment the "gr.comments" line.
autoCloseIncidents();
function autoCloseIncidents() {
	var ps = gs.getProperty('glide.ui.autoclose.time');
	var pn = parseInt(ps);
	var queryTime = new GlideDateTime();
	queryTime.addDaysUTC(-pn);
	if (pn > 0) {
		gr.addQuery('incident_state', '6');
		//gr.addQuery("number", "INC0000054");
		gr.addQuery('sys_updated_on', '<', queryTime);
		while(gr.next()) {
			var resolvedTime = new GlideDateTime(gr.sys_updated_on);
			var days = 5;
			var nowDateTime = new GlideDateTime();
			var dur = new GlideDuration(60*60*24*1000*days);
			var schedule = new GlideSchedule('090eecae0a0a0b260077e1dfa71da828'); // give the sys_id of the schedule which is excluding weekends and holidays
			var finalTimeAfter5BusinessDays = schedule.add(resolvedTime, dur);
			// check if the 5 business days have crossed
			if(nowDateTime.getNumericValue() > finalTimeAfter5BusinessDays.getNumericValue()){
				gr.incident_state = '7';
				//  gr.comments = 'Incident automatically closed after ' + pn + ' days in the Resolved state.';
				gr.active = false;
				gr.update();
another approach here
How to Auto-Close Resolved Cases (5 Business Days)
13 REPLIES 13
Hello Ankur i will implement your solution and when it works i will mark as correct Answer.
Thank you Ankur
One question
What should be a value of property
Keep it as 5 instead of 7
@Marcin Witoslawski
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
Thanks!
@Marcin Witoslawski
Thanks!
