Incident autoclosure in 5 Business days
Marcin Witosla1
Hello ,
Is there a working solution to autoclose incidents after 5 business days excluding weekends and holidays?
I have searched other community topics but any of them not working
The best solution is to created a scheduled job fired daily and checking incidents resolved at date.
Any ideas?
Marcin
Ankur Bawiskar
@Marcin Witoslawski
You will have to check whether the current date is more than 5 business days of the updated time of the INC
// This script automatically closes incidents that are resolved
// and haven't been updated in the specified number of days.
// This number is a property in System Properties.
// To place a comment in the incident, uncomment the "gr.comments" line.
autoCloseIncidents();
function autoCloseIncidents() {
	var ps = gs.getProperty('glide.ui.autoclose.time');
	var pn = parseInt(ps);
	var queryTime = new GlideDateTime();
	queryTime.addDaysUTC(-pn);
	if (pn > 0) {
		gr.addQuery('incident_state', '6');
		//gr.addQuery("number", "INC0000054");
		gr.addQuery('sys_updated_on', '<', queryTime);
		while(gr.next()) {
			var resolvedTime = new GlideDateTime(gr.sys_updated_on);
			var days = 5;
			var nowDateTime = new GlideDateTime();
			var dur = new GlideDuration(60*60*24*1000*days);
			var schedule = new GlideSchedule('090eecae0a0a0b260077e1dfa71da828'); // give the sys_id of the schedule which is excluding weekends and holidays
			var finalTimeAfter5BusinessDays = schedule.add(resolvedTime, dur);
			// check if the 5 business days have crossed
			if(nowDateTime.getNumericValue() > finalTimeAfter5BusinessDays.getNumericValue()){
				gr.incident_state = '7';
				//  gr.comments = 'Incident automatically closed after ' + pn + ' days in the Resolved state.';
				gr.active = false;
				gr.update();
another approach here
How to Auto-Close Resolved Cases (5 Business Days)
13 REPLIES 13
@Marcin Witoslawski
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
Thanks!
asifnoor
Yes you have to write a scheduled job and use scheduels.
I have given sample code here on how to use schedules. may be you can use that and can write a scheduled job.
https://community.servicenow.com/community?id=community_article&sys_id=df6464c9db1ed4909e691ea668961...
Thanks for marking my comment as helpful. Kindly mark the comment as a correct answer if this has solved the problem.
Gaurav Shirsat
Hi
Please Check this OOB Functionality to Auto Close the Incidents
Please Mark Correct and Helpful
Thanks and Regards
Gaurav Shirsat
