03-03-2020 09:50 AM
Is there a max number of Question Choices that can be added to a Select Box? I have 11 choices and only 10 will show up when I click the select box.
I've seen potential answers that say to adjust glide.xmlhttp.max_choices (has a max of 15) or glide.ui.max_ref_dropdown (has a max of 25), but since these are higher than the limit of 10 that I am currently experiencing, I don't believe those are the answers.
Service Catalog
03-03-2020 12:13 PM
I figured out what was going on. Apparently I had set the question text to two different items, but then I accidentally set the value on both of those items to the same value. So that explains why one was not showing up in the list. After correcting this, all 11 items show in the list now.
03-03-2020 12:15 PM
Yea, that's what I figured, it had to be something on your end. I was just about done making a test select-box with 15+ choices to show you that it works as I mentioned above.
Anyways, glad you got it figured out.
Please mark any other post as Helpful, if it was and the Correct answer that helped guide you there as Correct.
Thanks!
