Is there a way to archive VTB cards on a guided or flexible board
Steve Chapman
I have found many comments around archiving VTB cards but they all suggest it's only possible on Freeform boards.
My question is; Is there a way of archiving cards on other types of VTB's (Flexible or Guided)??
If there isn't has anyone used another method of removing cards periodically from a particular lane on a VTB so it doesn't fill up to monstrous proportions??
Any help much appreciated.
Many Thanks
Steve
scott barnard1
Hi Steve
Not sure archiving is the key there but you can create a data retention routine to archive the tasks from the system in general but it's probably not wise on a weekly basis.
However you could go to the Visual Task Board area open the board record in the navigator and add a filter condition with an "or" condition of state is closed complete && closed closed before last week or whatever you want in terms of date?
Steve Chapman
That sounds like a good shout Scott, l will give that a go and then mark your reply based on my findings.
Many Thanks
Amber9
Hi All!
I have same question, but different use case. I have created a Guided Board, based on a project, with lanes for To Do, Work in Progress and Closed Completed (based on Status(state)). I want to give users the ability to delete a task card straight from the board (the way you can with Freeform boards) instead of having to open the project > go to the task and delete it there. This is in the event that a task is no longer needed or was created in error.
Is there a way to delete a task card (and essentially the task) directly from the Guided Board?
